Texecom Premier Elite 24 Questions
37 minutes ago, datadiffusion said:
Thanks but there is no god given right to be hand-held through the settings, neither from the manufacturer, who provides training courses for professional installers,
nor from us. Plenty of help has been given, and I hope you get it working, but, as Yeti said an alarm is much like a ZX Spectrum; 'don't worry, you cannot break
the machine itself by incorrect programming'. Have a play, make changes, see what happens, if it doesn't work, put it back to how it was. That's why Wintex is so useful.
Datadiffusion, I never said that I have a God-given right.  All I'm asking for is only one person to tell me which settings to enable/disable on wintex.  I don't mind posting the screen shots again, just in case I've missed or made a change that I'm unaware of and for someone to check and tell me if what I'm doing wrong.
FYI, I've already backed up the alarm settings and tried a changing settings, but have had no luck.
  • Replies 60
  • Views 16.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Swb code name gorilla will be on scene soon be patient
  • You could check the "Quick Arm is On" in the keypad options menu. With the landing PIR attribute "Part 1 Omit" checked. Then you can part set by pressing Part then Yes on the keypad without using a ta
  • Read manual? Some of it will be easy to understand so why not read , set and test
Posted Images
unfortunately I don't know that panel at all
Don't be sensitive we have alarm monkeys for that, get setting and set unset and report back
Okay, so I followed Mark's instructions and edited & saved the settings in wintex.
I scanned the fob.
It asks do u want to arm?
I chose part-arm
It asks suite A or B
I chose A
It now wants me to exit the front door in order to activate the alarm
But I'm trying to set it up so that I can activate it at night, i.e. front door needs to remain closed.
Using the keypad change the exit mode to something different eg- Exit terminate
exit engineering, got back into engineering & change it back to times exit & see if it works ?
Hi , I'd default the panel and start again. Don't bother with two areas or Area Arm Suites. Everything in area A. Landing Part 1 Omit. Keypad Quickset on. Hall Guard Access. Part Arm Silent. What can go wrong? Press Part then yes at night. Landing will be off, Hall will be Entry. Jim
Second that.
No point complicating things as previous.
I also agree, but just so that I don't mess up the whole lot, how can I backup the current settings on wintex?
Also do you need to know the layout or what I want from each sensor?
