Texecom Premier Elite 24 Questions
So with Auto Part Arm set on for Area A you still have an issue?
Have you set the Area Arming Mode to Entry/Exit.
I believe it uses to Exit Timer to decide when to Part Arm.
  • Replies 60
  • Views 16.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Swb code name gorilla will be on scene soon be patient
  • You could check the "Quick Arm is On" in the keypad options menu. With the landing PIR attribute "Part 1 Omit" checked. Then you can part set by pressing Part then Yes on the keypad without using a ta
  • Read manual? Some of it will be easy to understand so why not read , set and test
Posted Images
Default and start again , if swb says it works it should work, you missed something or have done something else preventing it from working
Sounds like it...
I think it's easier if I posted screenshots for you to check.  Please let me know if you can spot any mistakes.
Thank you.
Sorry never used Texecom in anger. Will need one of the texe gurus to help here
Mrhappy and Sixwheeledbeast - I'm really sorry guys, but you'll have to be very specific for a dummy like me.  What screenshot are each of you referring to and what options do I need to enable/disable?
Thanks again
