Bentley F133 Revisited.
  • Replies 37
  • Views 7.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • probably only me thinking of Hale & Pace?     The OP is probably the only poster ever to put his postcode in "location",  I think I speak for every one on TSI when I express my
  • datadiffusion
    datadiffusion
    Well it certainly won't be any TV commissioner any time soon
  • PeterJames
    PeterJames
    They stopped making 2.6 ah in 1998 the battery should be changed evey 4 years so at the very least the battery has been pulling the charging circuit down for the last 18 years I bet the transformer hu
Posted Images
Well I suppose if the repairing of the alarm doesnt work, you can donate it to the Black Country Museum
Hadn't thought about that,  Good call.
Doubt if it will go ding-a-ling again.
1 hour ago, MrHappy said:
google translate comes back negative...
You need to turn safe search off.
The OP is probably the only poster ever to put his postcode in "location",  I think I speak for every one on TSI when I express my deepest condolences for living nr Dudley ?
Where's ya tool !
2 hours ago, Logan said:
Is that your mates at the office when you told them that you wont give them any bonuses
I don't have any mates,
Its the microwaved cat soft ball team...
Hi,
From the panel schematic I am assuming I have a SCB in the bell box,  is that correct,  I've not been up to it yet either?
The fuse F2 is good.
The battery YUASA NP12.6-12 12v.2.6ah has expired as it only read 4.5v when I measured it, what would peeps replace it with?
Even with a good 12v battery and powering pins 7&8 in the panel the bell does not ring so I suspect that it is buggered as well.
I'll keep playing.
Cheers
You maybe lucky and it's just a couple of sealed lead acid batteries of the same voltage and dimensions that you need to replace, for now.
