1 hour ago, MrHappy said:
look gardtec ish ?
Looks more like the one-zone keyswitch panels I sometimes see (badged as Tunstall, presumably monitored via the existing carelink) & I imagine sold as £800 'extras' on 1990s retirement flats.
  • Replies 25
  • Views 13.1k
  • Oh dear "Jock McTightSporran" is asking a forum which mainly populated alarm monkeys why their employed.   What goes wrong with your simple house alarm?   Well there will be at lea
  • Duff battery due to lack of routine maintenance etc has probably knackered the charging circuit and the pcb, it's had a good innings though!-more luck than anything else I would hazard a guess.
  • I think its a stripped back version of the C+K Active 5 , sold through Wickes in the 1990's.
you would know
it does look gardtech 300 ish in a different plastic
12 hours ago, norman said:
Sundials
I dont know, this one worked fine until about the fifteenth century then it started losing time.
Duh! It's like the 00s yeah, just rig up a nice bargain shop £4.99 10w LED flood and then your sundial works again, simples yeah?
Edited by sixwheeledbeast
I assume "challenger" to be CEF ?
They've had rebranded C&K securitech in the past, I can't recall ever seeing the plastics before ?
Yes if you google Challenger 5, like a sad c**t would, you come back to here but ten years ago where Wickes is mentioned...
Plastics are deffo the same as the oddity Tunstall keyswitch panel I keep seeing on my rounds. It doesn't have a single indicator on it,
just a keyswitch and might have the word 'ambassador'. Never seen in anything older than mid 1990s, usually right next to this type
of more modern residential care panel;
As before I assume it's an overpriced 'intruder' granny robbing add-on to carelink
Edited by datadiffusion
Plastic alarm monkey
