Replace Paragon plus with new version
56 minutes ago, Logan said:
Ventcroft primia 2  yes it is compatible but i recommend you replace it as its 20+ years old but its up to you if it still works
Heres a suitable Replacement
You can download the home control app without needing to be a engineer
Thanks Logan, yep was going to replace, just waiting for summer to change.
Can you resend the link for a suitable replacement.
  • Replies 62
  • Views 15.6k
2 hours ago, Logan said:
Im not really a fan of new elmdene (since when they moved to Chinese production)
The pic is a pre phone day Elmdene Prima
Phone day was in 1995,
I fail to see why anyone would want to retain a knacked old alarm box even "until the summer"
  • 3 weeks later...
I am looking to upgrade to Euro 46, reviewed all the instructions. However before i start tampering with the old setup. what is the best way to remove old panel without triggering the external siren. I do not have the engineers code and one of the external sirens is difficult to access at this moment
Disconnect mains and leave dangling on the side with battery inside
Or just take it off and let it bell for 20mins
Can someone please clarify how to rewire the external sounder from the paragon to the Pyronix, i have attached the diagrams. I am assuming that
Old Paragon [B+] & [B-] to Pyronix [B+] to [B-] respectively (easy ones)
Old paragon [BA]  to Pyronix [Bell]
Old paragon [BT]  to Pyronix [TR]
Old paragon [STB+]  to Pyronix [STB]
Old paragon [-STB]  to Pyronix [B-]
  • 1 month later...
Is there any other way yo wire up the external sounder, as when the alarm sets it blows the fuse and also sets the SAB tamper fault on the reader
It must be wired incorrectly. You have an output that is going active on armed connected to something
