Scantronic 4600 door contacts not functioning
Do you need it, can it not be disabled, if your using the terminals? It's been ages since I seen one.
Repurposing a reed from something else maybe hit and miss they are fragile.
  • Replies 80
  • Views 19.1k
  • james.wilson
    james.wilson
    helmand province?
  • PeterJames
    PeterJames
    We are in Storrington West sussex but we are not the cheapest company, (we are not the most expensive either) it depends on what you want  but we only supply quality kit which we install professionall
  • PeterJames
    PeterJames
    You can solder new batteries on these Ive done it in the past
2 hours ago, PeterJames said:
In your shoes Id buy a grade 1 surface contact and remove the reed from that
This is worth the try
Providing you know how to solder and not butcher
I'd suggest it's past it. But if you want to keep it I'd bridge the Reed and use the external connections only. But as its the oldest electronic thing in your house it must be time to upgrade or if your not fussed just decommission it
You ought to look into wireless polling etc not just assume a signal will make it. The rf environment is way different now than when that was considered good
Actually that might be better but you could also cut the reed up top and use the legs to solder to rather than messing the board up
Agreed about rf
Exactly if it's the on board reed, just wire externally and jumper the on-board.
(I mean honestly I'd bin the lot as discussed ad-infinitum but that is at least a no-solder solution)
Edited by datadiffusion
Changed the reed switch. All works fine now. Good for another 20 years
Thank you so much to everyone that responded
LOL!
Good job
Although 20years? Hahaha
well done,
you'll now be able to put you feet up & listen to your 8 track or maybe give your talbot solara another coat of autoglym...
