Automatic garden and hanging basket watering system
Project for today etc using solonoid valve and 10mm plastic speed fit fished in
  • Replies 81
  • Views 14.8k
  • Pricks ...
  • Nova-Security
    Nova-Security
    Irrigation system covered   Next, artificial lighting and electric meter by pass
  • Lol I've just been doing a pir activated motorised valve jobby, issue with the solenoids are hammer when they are activated.
1001700771_Screenshot_20200413-162032_Teams3.thumb.jpg.36c8d83bf874171a8e7e982dcf0b69bf.jpg1777224717_Screenshot_20200413-161905_Teams4.thumb.jpg.6e3863eed670a0b4417af42b06416a53.jpg
Edited by norman
would i be better of with a motorised one then?
Solenoids are OK and cost effective but they shut the water off suddenly and this has potential to exaggerate any weak points, tbh for 10mm I doubt it'll be an issue.
I've used these with the manual override due to the application, cheap and cheerful.
https://solenoid-valve.world/product/820/connexion/12-electrically-actuated-ball-valve-9-24vacdc-or-110-240vac-abvm04s
56 minutes ago, sixwheeledbeast said:
Wouldn't speedfit stuff suffer from fatigue being outside?
Gets brittle but lots of pubs use it? Guessing maybe uv rated but probably not due to it not being critical?
The Sun uses wordpress? Wow.
What timer are you using and what voltage is the solenoid?
Eta just seen the remote, I have a similar one in the garage, little 12v relay and 2 remotes marked A and B iirc, bang good special.
