Which Honeywell Panel in UK? - Gave up waiting for Konnected.io
  • Replies 131
  • Views 30.1k
  • datadiffusion
    datadiffusion
    Does not compute   LOL just about sums the market up.   £2k budget for HA £20 budget for security panel
  • GalaxyGuy
    GalaxyGuy
    I'm currently working on a virtual RIO module as part of something that I want for my own home automation.  I'll sell this for the bigger panels like the FX100+ and GD96 upwards, as they have lots of
  • james.wilson
    james.wilson
    Getting any eu compliant panel to talk to a non graded system isnt currently doable out of the box. You can obviously use relays and such like but not ideal. I use home assistant with my hkc system bu
39 minutes ago, sg86sg said:
I thought the GSM module was for backup for dual path signalling is that not right?
Can you expand on what is too small about the flex20? Im not using the door control and only have a 5 bed house so tbought it would be ok as it says for medium size businesses!
No you need a polled solution for dualpath with backup etc
However it may do it on the app as the vanderbilt, hkc etc push alarms through to the arc from the app platform not sure on the honeywell have never used it that way.
ie the size yes it will do re size but maybe not for flexability. What your doing most 'medium' sized business wouldnt be doing
4 hours ago, sg86sg said:
Everything is already run, I've run all the sensors many months ago when we had a lot of work done, alone with probably 50 Cat6 :D
I'm going with the Dimension or Flex, just deciding atm.
Are you saying you used Cat6 for the alarm cables?
How I first read it, but I then thought not.
6 hours ago, MrHappy said:
1/2 dozen Napco DT's & one of those nice internal SAB in the speaker case
Oh yeah I forgot they didn't do their own dualtechs did they?
I've still got two of their 'flat lobby' SABs with the totally translucent case, because you never know!
Edited by datadiffusion
6 hours ago, sg86sg said:
I talked with AMCO because they....
Your on the internet asking a random bunch of spackers how to do your alarm....
If the choice was between you & AMCO to do my alarm, I'd choose you ;)
Gone for this kit:
  • C005-M-E2 - Flex 20 Panel v3.1 Firmwar
  • CP050-00-01 - MK8 Keypad
  • CP037-XX - MK7 Keypad
  • A083-00-01 - Ethernet Module v3 firmware
  • A073-00-01 - RF Portal v3 firmware
  • A081-00-01 - GSM module
mk7 & mk8, strange...
I thought it was all DIY connection to an arc somehow
I miss these...
2 hours ago, MrHappy said:
Your on the internet asking a randy bunch of security specialists how to do your alarm....
If the choice was between you & AMCO to monitor my alarm, I'd choose you ;)
fixed
