Karizma control panel blank....
Ok it's asking for the engineer code which according to manual should be #### but for some reason that's not working ....
so looks like I'll have to get alarm specialist out to take a look .......
shame I thought someone on this site could give me a solution.......
Edited by datadiffusion
Code hidden AGAIN. OP please stop putting engineer codes in public as per forum rules.
  • Replies 20
  • Views 6.2k
  • datadiffusion
    datadiffusion
    This code is the default code, which we ask you not to post as per forum rules. It will have been changed by the original installer. Can you see the potential problem if it was not changed...?
  • there's Karizma, Karizma+ & a Karzima UDL   even if we fitted it we'd have little interest in supporting it,    You'll be lucky if you can find someone who'll supports the cabl
  • Excellent you answered your own question, £104 question .   Ps , means you found the manual and know how to default the panel and can programme it , easy as that
You'll be lucky if you can find someone who'll supports the cabling
This is an obsolete system prone to sudden failure. I have replaced many, usually they fail at 3am with sirens blazing, or perhaps during a holiday.
Shame I thought someone on this site could give me a solution.......
The solution is to default the system, though not the best one. We don't give that information out on here, you would rightly be very annoyed if a burglar could simply log in here and gain access to your system, surely?
You can find the engineer code within 2 minutes but clearly whoever  installed the alarm has changed that default code
anyway this site has given me no useful answers
so I'll be withdrawing from it
very disappointing
very disappointing
Glad we could be of service
very disappointing
Edited by al-yeti
They would be stupid not too.
very disappointing
The useful answer was already given below in red
26 minutes ago, John 4 said:
Very disappointing
To be fair this pretty much sums up the Karizma and iD wiring with the benefit of hindsight.
I was just about to offer some sterling advice, ah well, never mind.
