False alarm
  • Replies 20
  • Views 4.8k
7 minutes ago, Search1231 said:
thanks for your responses, what beams would you reccomend
if the building is open to the elements, wired external beams,
which probably means your ebay stuff needs relocating to a skip
you also should be looking to contact all the doors
any wiring needs to be protected for the birds
pic of the alarm panel, it has 8 wired zones,
just a question about beams, i have around a 1-2ft section of void across majority of the roof, the cages are below, the metal roof is above, if i am using beams which are say 20cm high, am i right in thinking the beams will travel  within that 20cm height, if the beams had say a 50cm height, then the beam would travel through a cage and will get triggered, i could do with some clarity on this please.
This looks like the stuff Peter James imports/supports, he'll be along shortly...
pic of where it should be fitted....
514543-metal-skip-full-of-building-rubbi
Optex or Takex for beams.
You will need a proper alarm system to connect it too.
As with a lot of electronic products on ebay, buy cheap buy twice.
I would suggest you give a few local companies a call to see if you can get a good quote for a fitted system.
an active beam is a point to point device so needs very little room. think of a James bond stylee laser beam, break the beam and the receiver activates
All about budget now, I am sure everyone appreciates you may not be able to get something good installed , but you will go in circles
I am sure the birds cost a bit and better you save up , do it once so you don't have to mess around
Have you got a budget ? £1200?
Can the pet get within six foot of the detector, I guess so its a bird.
Your not funny, I am selective with my imports, I dont import anything thats likely to spontaneously com-bust.
