Not sure if you were jesting but an hour for an hour after 12am, ie go out on call at 1am, get back home at 3am, report into work at 11am (presuming you start at 9 of course)
Edited by antinode
Trade Member
Anti how does it work (wolf)
ie you do a night on call and get some etc
hour for hour recovery time after midnight, out for 3 hours (from leaving house to walking back in) start 3 hours later the following day.
Correct me if I'm wrong, but I'm sure last time I fitted an EV-105, the neg is on the outside with the pos next to it (the link is the negative control line for the LED)
No rest time?
I'll look out for that.
Thanks for the tip with the bare wires too. This is just hooked up temp so I know what goes where whilst the room is refurbed.
I am sure we've covered this before. Some places don't care what you did last night your still expected in for half 8.
How does that work if you have a call booked for 9am? Just cancel it? If no other engineers are avliable that is?
Shouldn't be booking calls for you before 12 if you are on call prev night (I say shouldn't..)
Then they are wrong and you need to look elsewhere for someone who values your wellbeing and safety, duty of care and all that.
That rule Wouldn't work for me.
Last place I worked at had the rest time but I usually ended up going in for 9 anyway.
Register a new account
Sign in
