- 18 replies
- 18 replies
- 18 replies
DeedPopo joined the community
- 18 replies
hi -
al-yeti started following Ryan Godfrey and Looking forward to contributing and learning.
Yo -
- 18 replies
RGodderz joined the community
- 18 replies
- 18 replies
Dieter joined the community
- 18 replies
Stijn joined the community
Hello, I seem te be having a similar problem, yesterday my alarm started displaying the same issue. Only it had been working perfectly for the past 5-6 years. The problem now seems that my installer seems to have gone out of business and nobody want to touch this old thing. I'm capable of doing a reboot (disconnect mains and battery) myself but am wondering if this wil have any influence on the problem. Regards Stijn
Who's Online 0 Members, 0 Anonymous, 73 Guests (See full list)
Total Topics446.5k
