- Past hour
- 18 replies
- 18 replies
- 18 replies
- 18 replies
hi -
Yo -
- 18 replies
- 18 replies
- 18 replies
- 18 replies
Hello, I seem te be having a similar problem, yesterday my alarm started displaying the same issue. Only it had been working perfectly for the past 5-6 years. The problem now seems that my installer seems to have gone out of business and nobody want to touch this old thing. I'm capable of doing a reboot (disconnect mains and battery) myself but am wondering if this wil have any influence on the problem. Regards Stijn
Who's Online 1 Member, 0 Anonymous, 26 Guests (See full list)
Total Topics446.5k
