- Past hour
- 18 replies
- 18 replies
- 18 replies
- 18 replies
hi -
Yo -
- 18 replies
- 18 replies
- 18 replies
If you know what you are doing you could, but I wouldnt advise it if you know nothing about alarms and you dont have anyone you can call, or spare parts. The keypad is used to control the system, if you down power and power up and the keypad still doesnt work you wont be able to silence it. There could be a number of reasons why your panel has done this, if it hasnt been serviced in a while all the batteries will be u/s, it could be a cable has been damaged it could be the keypad has died. Post where you are (Town) there maybe someone on here able to help Galaxy is a well loved known brand and most good engineers know it even if its not their weapon of choice nowadays
Who's Online 2 Members, 0 Anonymous, 51 Guests (See full list)
Total Topics446.5k
