Automatic garden and hanging basket watering system
The spider manifold things are useful but I am still not a fan of plastic.
Can recommend trace as above, issue is the supply and would likely be an awkward run if you want to protect all the external pipe work as well
  • Replies 81
  • Views 15.5k
  • Pricks ...
  • Nova-Security
    Nova-Security
    Irrigation system covered   Next, artificial lighting and electric meter by pass
  • Lol I've just been doing a pir activated motorised valve jobby, issue with the solenoids are hammer when they are activated.
I can't say I'd use plastic inside for any plumbing all I've done on the kitchen etc has been copper and solder. But i can see why it's used on modern builds its very quick and easy compared to tube. I see push fit installed with joints in walls etc but I wouldnt
Wheres your non-return valve? Or is it on the tap supplying this?
Yes, it's a reg. to prevent any back syphoning.
But no different to a Std garden hose etc. And most don't bother with those.
Most garden taps will have them built in, even the cheapest B+Q tat I guess?
On a campsite where I look after a fire alarm they've gone one step further and now they not only need
the check valve but a device mounted on the tap to make sure any hoses left connected drain themselves.
Edited by datadiffusion
10 hours ago, MrHappy said:
I have a green watering can for water & a red watering can for weed killer...
same here
Oh no I havnt ill add one on the supply to it
This subject has got me thinking, I have one of those big square plastic tanks installed under the decking in the garden, its filled from rain water off the roof of the garage. We use it for watering the plants at the bottom of the garden using a hose and gravity.
The problem is its quite a long way and the pressure is quite low, also the tank fills very quickly over the winter and I could do with filling some more water butts at the bottom of the garden by the greenhouse, I was thinking I could use a submersible pump like they use  in caravan showers and stuff and switch it on and off via a sonoff relay. and another one that turns on when the tank is full to fill the two butts at the bottom of the garden .
