Replacing Home Alarm System
4 minutes ago, norman said:
I did have the heating linked to the alarm years ago but this overrides the frost protection so I dissed it and just use the nest jobby.
I use RF lightwave you can more or less instruct it to do whatever you need using IFTTT Frost protection is never overridden
  • Replies 39
  • Views 8.8k
  • the 9800 was in the market place in the late 1980's.... rkp, digi footprint, priner outputs...   30 odd years later-     this sort of tat still selling well.
  • I think they call it Cif now ?
I use ifttt but this was prior to it and pretty dumb really on the galaxy, just an octal relay wired to full set iirc.
My last house I had lights curtains and heating connected to my G500, it used to open and close the curtains switch lights on and off and control the heating on a timer along witha separate digital temperature thermostat. You could do anything the the outputs combined with JK flipflop and a few erl timer relays. My remote app was Galaxy gold back then, I used to have to stop the car,  connect my lappy to my phone physically and log into my alarm in order to switch the heating on on the way home.
7 minutes ago, Logan said:
I think the 9800 was kind of a dumb design using 2 7 segment displays like the 9100 from the late 80s.
Compared to the 9600 and 9500 that uses a lcd screen
Still want a 9500 lol
The 9800 was cheaper, a lot of people think an alarm is an alarm ie all the same so buy the cheapest
30 odd years later-
Original optima was a black and red membrane. The xm bought the buttons
Keep on like that he can then press the ignore button
We have that now using Nest, Fibaro, and IFFT, bit of a kludge but it works and is a one way path, there is no interaction with the alarm other than Norm style physical 'alarm is set' relay telling Fibaro home centre.
I'm not big on the blinds thing but for the main lounge (which also will suffer from too much sunlight in the summer anyway) I will have auto curtains on the french windows and auto roller blind the opposite end where the sun is worst.
? You set it up wrong I would say
Housebashers know better
