yale wireless hsa 3000 series tamper problems
hi , wonder if anyone could help with problems concerning yale wireless alarm hsa 3000 series
 when on sunny days the alarm go,s off on its own , i found out its the tamper switch inside the alarm siren box and the cover must expand with the heat of the sun causing the tamper switch to move , ive tried a few times to pack the switch so the switch is tight closed but after a while im back to square 1.
 the question is can i disconnect the tamper switch or loop the yellow and red wires together or maybe just fit a 12v on/off switch to bypass this. any help appreciated
its basically tat....
is the micro switch  has wires join 'em
if its on a pcb bridge it out with a solder iron
hi yea there are 2 wires going to the micro switch do you say its ok to loop the 2 wires together and remove the switch , the switch do,s plug into a pcb but id rather not mess around with it , the wire are yellow and red
Edited by gazh
39 minutes ago, MrHappy said:
if the micro switch  has wires remove the switch and join the wires
Fixed
48 minutes ago, PeterJames said:
Bin it, load of rubbish, got to be at least twenty years old
Fixed
Making it work isn't fixed. You can bypass it but it is low grade stuff
Thanks lads for the info its much appreciated , going to replace the whole lot soon just needed this sortin for now..which is the best wireless upgrade to go for
Hkc then perhaps texecon
1 hour ago, aissecur said:
not really used much HKC
You haven't lived until you have had the soft breeze of HKC wireless transmission wafting through your hair
