Access Control System Wiring
Hi guys,
I've purchased myself a simple access control system and I'm fairly confident I know what I need to do.
The power leads appear to not matter how they are connected (which does to + and -, as long as they are connected).
One thing I want to check before I start is what type of wire I should be using to connect the components. The "Power Supply Control" is a K80 (see attached picture).
The device will be outputting 12v DC (3A). I know this is not much different from the alarm system I installed a year or two ago, but I am unsure if I can use the same cable. The alarm cable is 8 core cable, so presumably I would slice it open and use a single strand - as per each required wire, but whenever something comes to electrics I always like to be 100% sure.
Will I be okay to use the wire in the manner I have described. Should I use all 8 cables per connection or should I be using a totally different wire entirely (taking an AC cable and using an individual strand of that) OR shall I use something else entirely. If you could include any information - as well as possibly links - to the best wire to use, it would be greatly appreciated.
Many thanks for your continued support guys,
John
  • Replies 21
  • Views 5.1k
3 hours ago, neon555 said:
Hi guys,
John
Alarm cable will do
No CE mark
Metal case = Class 1
Metal case is not earthed
oh dear....
1 hour ago, MrHappy said:
No CE mark
oh dear....
Hardcore cheap though
15 Dollar....
Edited by MrHappy
We'll that's ok then..
I would think twice before using this kit (for the sake of the user and your insurance)
Send one to bigclivedotcom for an appraisal.
google'd it & was surprised its was a sensible answer...
