December 8, 20178 yr comment_472177 Hi guys need some help . Urgently . Recently had some work done in my house and the fuse spur for the alarm has been blowing every couple of day for passed week. This Pir I’ve noticed has gone red also so was wondering if this could be the problem cause all the others have blue lights. If this cable was broken it’s only 12volt anyway so didn’t think this could be the problem the fuse in the spur was 13amps also , thought it should of been a 3 or 5 amp . Didn’t take the MCB out just blew the fuse . . Can anyone help me out . Many thanks guys , Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41794-help-guys/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 8, 20178 yr comment_472180 What kind of work? Any insulation Resistance tests carried out? sound like a dodgy power supply/transformer in the panel. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41794-help-guys/#findComment-472180 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 8, 20178 yr Author comment_472181 No nothing like that just some drilling , plasterboard put up . Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41794-help-guys/#findComment-472181 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 8, 20178 yr comment_472183 All electrical connection are tight? plasterboard/drilling anywhere near the panel? Power been switched off for a period of time? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41794-help-guys/#findComment-472183 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 8, 20178 yr comment_472184 the easy solution is find a tame alarm co. local to you... if you don't want to spend money, disconnect the alarm Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41794-help-guys/#findComment-472184 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 8, 20178 yr comment_472185 The PIR going red is because it’s seen movement those have a red LED in them , some have BLUE leds. Contact a local alarm Co. for assistance Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41794-help-guys/#findComment-472185 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 8, 20178 yr comment_472186 If your blowing 13A plug top fuses there is something seriously wrong on the mains side of the alarm (assuming only the alarm is connected to the spur). I would suggest isolating it and powering the system down until tests can be made to the electrical connections or control panel. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41794-help-guys/#findComment-472186 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 9, 20178 yr comment_472190 yeah 13A fuses take some blowing id get it looked at urgently securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41794-help-guys/#findComment-472190 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 9, 20178 yr comment_472194 Assuming spur is short distance from panel then they may have damaged cable coming out of the spur to panel Picture of spur? Panel? Internal of panel? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41794-help-guys/#findComment-472194 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 9, 20178 yr comment_472195 ^^^ Ooooh, you shoddy rip-off alarm fitter! 3 minutes ago, al-yeti said: Assuming spur is short distance from panel then they may have damaged cable coming out of the spur to panel Picture of spur? Panel? Internal of panel? And pic / sketch of work done / physical relation to panel please. Edited December 9, 20178 yr by datadiffusion So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41794-help-guys/#findComment-472195 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
