Thank you Mrhappy.  As you can see, I've updated it and now when I arm the alarm and press the "PART" button on the keypad. Normally I would get the choice menu which would allow me to choose Bed alarm 1, but now I get the choice of Suite01.ArmArea A.  After choosing this, there is no timer countdown at all.  Instead I have to open and close the front door to activate the alarm.
Thank you sixwheeledbeast.  On prev page, where I've posted the Area3 screenshot, it already is Timed Exit.
Also you say you wouldn't use the Area Arm suites, but this is now becoming confusing, because I'm not sure which options need to be enabled/disabled as I've got two different advises..
Could I please ask u a big favour?  Using all the screenshots that I've posted, could you please draw or at least clearly explain PER screenshot what you want me to change, enable or disable.
You could check the "Quick Arm is On" in the keypad options menu. With the landing PIR attribute "Part 1 Omit" checked. Then you can part set by pressing Part then Yes on the keypad without using a tag or PIN. The hall is already Guard Access so it will be entry in part set. Jim
  • Upvote 1
@datadiffusion - Phew! You got me worried as I thought you were serious mate :D
@Jim Randle - Thanks Jim.  The problem I have is that I've now got mixed up with the settings that I've already been told by sixwheeledbeast and mrhappy, so I'm not sure what to leave on and what not to.
I'd be ever so grateful if someone could maybe get the screenshots I've already posted and draw with arrows, what to leave on and off?
Register a new account
Sign in
