agreed anyone still using it? but the original dt700 wasn't quite right with it.
Thanks chaps- is there a specific technique to adjust the MW range?
Also - does anyone know if the Texecom DT's come with resistors and also the resistor values required if not? (so i can get them ordered). Or will it be a simple case of a 2K2 across the alarm/tamper and a 4K7 across alarm/alarm terminated at the PIR, as seems to be the standard - each zone (one PIR per zone).
My main kit turned up yesterday and included an alarm box and some prox tags too, quite impressed considering they weren't advertised. Had a sneaky hour read through the installation (can only find the Premier Elite 24 guide online as opposed to the 24-W) and quick reference guide (included) - oh my life! This is going to be muchos fun programming :lol: quite looking forward to the challenge once I've got it all hard wired in.
Edited by 1animal1
The MW usually has a pot to adjust it's easy identifiable. Turn the MW right off and then slowly adjust back on until it covers where you need it.
  • Upvote 1
Thanks Norman - gather this will become clear on the PIR instruction leaflet?
I've just ordered a Texecom premier elite DT for this job - after debating over the specs of 4 different DT PIR's on their site...how do you guys choose? pick a favourite and stick with it??
