Setting up a Twin Piezo Sound Bomb
I don't understand anything these lot are on about
Anyhow to give you "new" ideas try using a different output , so example keep black on zero volts and then if a programmable output is available then connect red there and programme it to positive when in alarm if that's what you want
But now we need alarm men to answer next bit , when programming an output on this panel
Does he have to cycle it to make it take affect or come in and out of engineering etc blah? Come on you house bashing alarm men what you think?
On 7/31/2016 at 11:35 PM, MrHappy said:
I'd put the red on + & use op1 on black programmed as something suitable?
But then again it's late & I've been drinking....
I agree use opt1 which is next to the spk connection and program it as bell in wintex in outputs, panel outputs, area, option 28.
