al-yeti Posted October 27, 2022 Share Posted October 27, 2022 2 hours ago, sixwheeledbeast said: So? AG6 DIY and sparkie favourite... junk but available and popular. Everyone will have their own favourite panel and bell. If you have a sample size of 1 and it works for 10 years what's the issue... Ag6 though one of worst in weather , and doesn't have scb Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45363-scantronic-9853-tamper-message-reset/page/2/#findComment-516739 Share on other sites More sharing options...
JimM Posted October 28, 2022 Author Share Posted October 28, 2022 Thanks again for the info Jumper from TR to 0V at the panel clears the fault, tried jumpering the TR to H- (presumably this is 0V) at the bellbox and fault remains so guessing there is an issue with the cable. Can't be a complete break as power still getting to bellbox as when I disconnect the H+ terminal bell stops ringing. To try and confirm that it's just an individual core (or possibly more) I intend to 'pair' the cables up at one end and test continuity at the other - does that sound sensible? Hopefully if it's just one core broken I think there will be a spare one I can utilise as only 5 cores out of the 6 are used. Pyronix bell looks as good as any to me, so probably will go with one of those if needed. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45363-scantronic-9853-tamper-message-reset/page/2/#findComment-516741 Share on other sites More sharing options...
sixwheeledbeast Posted October 28, 2022 Share Posted October 28, 2022 Yes, and yes as a temporary fix. It's down to if there will be further damage to the wiring in the near future. Something could be crushed or being chewed at for example. Also consider that you need 5 cores minimum, so you will have to cross check when pairing your cores. If it's the wiring and the bell and as important it's battery are in good working condition; there is no need to replace. When I say cross checking multiple pairs but also open circuit between everything too. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45363-scantronic-9853-tamper-message-reset/page/2/#findComment-516742 Share on other sites More sharing options...
JimM Posted October 28, 2022 Author Share Posted October 28, 2022 The bell battery is a bit suspect, was surprised that with the bell box open and ringing, disconnecting the H+ lead stopped it, I assumed some sort of battery backup should have kicked in? Didn't check to see what sort of batteries it took but will swap them out if I can. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45363-scantronic-9853-tamper-message-reset/page/2/#findComment-516743 Share on other sites More sharing options...
sixwheeledbeast Posted October 28, 2022 Share Posted October 28, 2022 Removing the hold off voltage should trigger the bell so best to replace the whole unit. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45363-scantronic-9853-tamper-message-reset/page/2/#findComment-516744 Share on other sites More sharing options...
JimM Posted October 28, 2022 Author Share Posted October 28, 2022 Thanks, makes sense and for the price of a bell not worth messing about Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45363-scantronic-9853-tamper-message-reset/page/2/#findComment-516745 Share on other sites More sharing options...
al-yeti Posted October 28, 2022 Share Posted October 28, 2022 3 hours ago, JimM said: Thanks again for the info Jumper from TR to 0V at the panel clears the fault, tried jumpering the TR to H- (presumably this is 0V) at the bellbox and fault remains so guessing there is an issue with the cable. Can't be a complete break as power still getting to bellbox as when I disconnect the H+ terminal bell stops ringing. To try and confirm that it's just an individual core (or possibly more) I intend to 'pair' the cables up at one end and test continuity at the other - does that sound sensible? Hopefully if it's just one core broken I think there will be a spare one I can utilise as only 5 cores out of the 6 are used. Pyronix bell looks as good as any to me, so probably will go with one of those if needed. You haven't had stair carpet fitted recently have you? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45363-scantronic-9853-tamper-message-reset/page/2/#findComment-516746 Share on other sites More sharing options...
james.wilson Posted October 28, 2022 Share Posted October 28, 2022 AG6 proves the point of hugely popular because it was cheap. Low cost stuff always sells better than premium regardless of the quality. I personally wouldnt go for a pyronix bell but again pyronix is popular... 1 securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45363-scantronic-9853-tamper-message-reset/page/2/#findComment-516747 Share on other sites More sharing options...
MrHappy Posted October 29, 2022 Share Posted October 29, 2022 10 hours ago, james.wilson said: I personally wouldnt go for a pyronix bell but again pyronix is popular... Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45363-scantronic-9853-tamper-message-reset/page/2/#findComment-516749 Share on other sites More sharing options...
Imnotshankled Posted October 29, 2022 Share Posted October 29, 2022 17 minutes ago, MrHappy said: We all love the enforcer its amazing Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45363-scantronic-9853-tamper-message-reset/page/2/#findComment-516750 Share on other sites More sharing options...
