Eurosec CPX control panel
Hi all,
I've had the above panel installed with a wireless alarm for a number of years.
It's got to the time of year again where one of the batteries in the wireless motion sensors is running low and triggering the alarm.
This is becoming more and more frequent as the battery gets lower.
My installer has stated that they cannot remember the engineers code.
What options do I have?
I'm not sure if removing the sensor and replacing the batteries whilst the alarm is sounding will sort it.
Thanks,
Dave
He will need it to service the alarm etc Id ask him to sort it.
But im assuming you have no support contract on it?
You have two options if your doing yourself... try it and hope or no system.
The installer should know how to deal with a lost engineers code, which may involve reprogramming the system.
You should leave it up to them if you are under support obviously.
CPX didnt have any wireless detectors IIRC so they must be aftermarket with a receiver. The CPX has a built in Digi so is normally monitored. Strange combo monitored alarm with aftermarket wireless detectors.
lol,
its supports a single wireless expander, 8 zone + 8 keyfobs, reports, alarms tamper, low battery ect...
the digi works as speech dialler,
its not a bad product, but gardtec quirky with cheap looking rkp
Never used a cpx but hated the cp8l used as a necessity after the 800l however quite stable hardwired
went from 700l to vertias, then to euro mini as staff could not cope with led keypads (honest)
On 02/11/2021 at 11:44, DaveItalia90 said:
Hi all,
Thanks,
Dave
Pay someone to put something upto date in....
  • 1 month later...
Re the CPX
Risco have now reduced significantly their product range to the point that after almost 30 years with the brand we have moved off to pastures new.
The CP8 and CPX have been removed and replacements can not be sourced, they are incidentally still supplying the detectors as they are used on other items in the Risco range.
They have also removed from the shelves the Commpact system and many of their external sounders (We had over 50 printed covers for one unit that have now been skipped as useless)
Re the engineer codes, there is an option the reset codes provided they are not locked your engineer should know how to do this (if he's worth his salt).
9 hours ago, Slickjack said:
Re the CPX
They doing you a favour , complete rubbish you just got used to ?
