May 14, 20206 yr comment_500996 Just taken over a couple of ATS systems that have access on a few external doors. Do these systems not have a timed egress function. Every one you have to hold the rte and open the door, rte just wired across the lock feed. Seems like a bodge way of doing it to me. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43815-ats-access/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 14, 20206 yr comment_500997 1 minute ago, AgsDave said: Just taken over a couple of ATS systems that have access on a few external doors. Do these systems not have a timed egress function. Every one you have to hold the rte and open the door, rte just wired across the lock feed. Seems like a bodge way of doing it to me. Is it wired across the lock feed for sure, did you check? I am not familiar with the ATS systems, but most access control panels have a RTE input. Normally the symptom you describe is because the RTE is wired into the controller as normally closed when it should be normally open or vice versa. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43815-ats-access/#findComment-500997 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 15, 20206 yr comment_501012 7 hours ago, AgsDave said: Just taken over a couple of ATS systems that have access on a few external doors. Do these systems not have a timed egress function. Every one you have to hold the rte and open the door, rte just wired across the lock feed. Seems like a bodge way of doing it to me. Allot of single door controllers are like this cheaper stuff so don't suprise me on the ats Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43815-ats-access/#findComment-501012 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 15, 20206 yr comment_501023 As PJ, sounds like it's just breaking the power. Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43815-ats-access/#findComment-501023 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 15, 20206 yr comment_501031 Slightly surprised there isn't a zone attribute called Rex though, Siemens has both Rex zone and dedicated Rex on the door card iirrc. Not sure about texe? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43815-ats-access/#findComment-501031 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 15, 20206 yr comment_501032 dont know it but even the micromax has an input. Id assume it was wired wrong. Once met someone that thought wiring the breakglass to the rte was better than breaking the power as it allowed for programming!!! securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43815-ats-access/#findComment-501032 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 15, 20206 yr comment_501033 Have a look for a Door RAS ATS1170 they have a RTE button input which is timed programmable www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43815-ats-access/#findComment-501033 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 16, 20206 yr Author comment_501109 Thanks for the replies. Was just curious as to why the rte was inline with the lock feed, and if I was missing something obvious. They look to be done using a transistor driven relay straight off the reader with data to the panel, And not via a door controller card. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43815-ats-access/#findComment-501109 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
