ADEMCO ACCORD 8
I have to omit the zones each time to set the alarm by User code + 6 then press 5,6,7 * then press easy set #+1 then this set the alarm. It will set alarm off if the PIR is obstructed. But once I do this or open door and enter the code. I have to manually do this process again! Any support would be appreciative.
  • Replies 52
  • Views 9.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • These manuals are searchable by anyone on the World Wide Web. Why the issue?   If you don’t have anything supportive to say please don’t contribute anything.    Off topic: Yes as e
  • I don’t think people really can be bothered with what you have stated. Instead you have just wanted to be differcult... and proven unhelpful  - Take your power elsewhere Logan - and remember with grea
  • its funny how one thing links to another...
Posted Images
Those zones need programming out
That's why omitting allows it to arm
You are manually omitting those circuits that's how it should work, omits are temporary.
Permanent changes are done with programming or wiring them out.
On 23/02/2020 at 17:48, PeterJames said:
Have you tried linking out 5 6 and 7 ? If you have a multi meter then see if they are cc
You try the above yet?
1 hour ago, Timmymeads said:
I have the programming code - How do it do it?
Did you try what Peter James said?
To be fair if you dont understand that much, its not a forum you need its an engineer.   Linking out a wire across each circuit in the panel, take the existing wires out. Before you open the panel isolate the mains electricity can kill
Yes I can link out and no how to do it just need to figure which wire is for which.l, I don’t have a multi meter but there might be instructions. I was more if I could do it through the panel system
44 minutes ago, Timmymeads said:
If I link out 5.6.7 zones then if I use easy set will it arm?
If it does then you know the problem is with the wiring if it doesnt the panel is probably knackered, tak a photo for ref before you start, remove existing wires because a short to tamper would also indicate open zone
