ADEMCO ACCORD 8
Shall I take our 5.6.7 zones only and join them together and cap them only. Then try alarm ?
  • Replies 52
  • Views 9.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • These manuals are searchable by anyone on the World Wide Web. Why the issue?   If you don’t have anything supportive to say please don’t contribute anything.    Off topic: Yes as e
  • I don’t think people really can be bothered with what you have stated. Instead you have just wanted to be differcult... and proven unhelpful  - Take your power elsewhere Logan - and remember with grea
  • its funny how one thing links to another...
Posted Images
Put links in theplace of the wires you took out
Ah I see just 2 wires between 3 zones - then the wires I took out originally just cut them back and insulation tape?
Remove circuit wires, dont worry about taping them they are not live, put links in each circuit. If you are not sure what you are doing then get someone who is to do it
Thanks for your help Peter - I’ve done it and it all works like it should!
nice one mate
Hi Timmy puting the links in only proves the fault is not the panel, you havent fixed the fault at all, the detectors will not trigger the alarm if you have removed them
Hi Peter,
There was no wires originally in 5.6.7 so I linked them in.
When I do a easy set it gives me a different sound like the one when I omitted the zones manually. It does 10 second count down and then it sets. I stayed in the house and walked to a detector and the main alarm sounded so think all should be fine. I’ll try the other detectors too
5 hours ago, Timmymeads said:
Hi Peter,
That makes more sense t sounds like they were originally switched off in the programing and some how you switched them on, linking them out is as good as deprogramming them
  • 3 weeks later...
Peter - How do I enable night set - I’ve tried #+3 and get 3 beeps - Pretty sure one programmer it aswell and nothing?
