sixwheeledbeast Posted April 13, 2020 Share Posted April 13, 2020 Sounds like something is wired wrong or broken to me. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43520-replace-paragon-plus-with-new-version/page/4/#findComment-498506 Share on other sites More sharing options...
james.wilson Posted April 13, 2020 Share Posted April 13, 2020 Maybe upload photos of each end showing the connections and markings? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43520-replace-paragon-plus-with-new-version/page/4/#findComment-498507 Share on other sites More sharing options...
Guest Posted April 13, 2020 Author Share Posted April 13, 2020 I cannot get access to the bell at the moment, however i have not changed the connections there, I labelled where it was wired into the original panel. (note i need to reduce the exposed wires in the picture) B+: Red B- : Black BA : yellow STB- : Green STB+: White BT: Blue Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43520-replace-paragon-plus-with-new-version/page/4/#findComment-498510 Share on other sites More sharing options...
PeterJames Posted April 13, 2020 Share Posted April 13, 2020 Did you change anything other than the bell? I would start by removing the strobe and bell (yellow and white wires) then see if arming still blows the fuse then put them back one at a time to see whats causing the problem. My money is on strobe Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43520-replace-paragon-plus-with-new-version/page/4/#findComment-498511 Share on other sites More sharing options...
Guest Posted April 13, 2020 Author Share Posted April 13, 2020 I replaced the panel and added 2 new PIR's, The external sounder / strobe is the same. I will try that, however i need to buy more fuses (this will be interesting at the moment!) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43520-replace-paragon-plus-with-new-version/page/4/#findComment-498512 Share on other sites More sharing options...
MrHappy Posted April 13, 2020 Share Posted April 13, 2020 1 hour ago, Guest said: I cannot get access to the bell at the moment, however i have not changed the connections there, I labelled where it was wired into the original panel. (note i need to reduce the exposed wires in the picture) B+: Red B- : Black BA : yellow STB- : Green STB+: White BT: Blue you've wired the strobe wrong... Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43520-replace-paragon-plus-with-new-version/page/4/#findComment-498517 Share on other sites More sharing options...
Guest Posted April 13, 2020 Author Share Posted April 13, 2020 Which way should it be? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43520-replace-paragon-plus-with-new-version/page/4/#findComment-498522 Share on other sites More sharing options...
MrHappy Posted April 13, 2020 Share Posted April 13, 2020 stb on the alarm panel is 0v applied when the alarm tell the strobe to flash green in stb white in b+ Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43520-replace-paragon-plus-with-new-version/page/4/#findComment-498526 Share on other sites More sharing options...
PeterJames Posted April 13, 2020 Share Posted April 13, 2020 1 hour ago, MrHappy said: you've wired the strobe wrong... 2 hours ago, PeterJames said: My money is on strobe Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43520-replace-paragon-plus-with-new-version/page/4/#findComment-498527 Share on other sites More sharing options...
MrHappy Posted April 13, 2020 Share Posted April 13, 2020 @PeterJames since its a bankholiday I thought I might do a helpful post, you know, mix it up a bit Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43520-replace-paragon-plus-with-new-version/page/4/#findComment-498528 Share on other sites More sharing options...
