Can you spot the obvious problem in this photo
Look closely at this photo. Can you spot the obvious error. Yes that's correct. They have not cut one of the cable ties. :-/
other than that it seems like a immaculate installation.
  • Replies 58
  • Views 15.1k
7 minutes ago, al-yeti said:
Your on crack yes?
Only at the weekends.
There is a hint of sarcasm in my post.
Is the sounder on with more than one screw  or fixed with cable clips if so its a proper job or maybe no more nails
and the local cable rules state staple guns and washing lines are also up to the standard of an approved installer
3 hours ago, al-yeti said:
Your on crack yes?
You wish you were!
34 minutes ago, petercts said:
are you sure the approved installer can read
Who said it was installed by an approved installer?
