Apollo 65 SD on Galaxy
Would this assembly work? I want my intentions scrutinised by the pro's before I carry out any installation.
Apollo 65 Smoke detector wired to Galaxy G2 complete with resistors, Zone programmed as Fire then equally an output (1001) programmed as Fire with a internal sounder wired into it (I use Pyronix Twin Alert) .
Smoke present.... Panel sees a fire activation so my sounder (in theory) will alert myself/the occupants?
Do you gents recommend any particular type of SD detector? Just using Apollo as an example.
Thank you
  • Replies 73
  • Views 20k
  • Each battery powered smoke alarm has its own sounder, should it detect a fire it makes a noise   A 12v intruder alarm has the sounder separate from the detection device, combustible cables m
  • Shaunb1905
    Shaunb1905
    Must be mental using twinflex!!
  • grade D can be connected to their own dedicated circuit or a regularly used lighting circuit   my preference is with the lights, more so because if there is a fault its usually noticed soone
you will need a 12v base / clean switch but the theory is sound. just bear in mind you need them well placed as if the cable/panel etc get compromised it cant do its job
Easier to buy a 12v detector or if you have existing mains smokes a relay base for one them providing you can get the cable to link it
Thanks James,
12V relay base though surely?
1 hour ago, sixwheeledbeast said:
Or a fire alarm system.
Not on a mid terrace mate.. Who actually installs a full fire panel system in their own domestic property?
Connections on this type of base... + -, say yellow & resistor leg into C, two resistor legs into NC, final resistor leg and blue core joined in choc block?
Used to service a gent Vigi system in a domestic in the sticks.
However it was a stately home with outbuildings etc.
Owner built it from scratch and had a full set of drawings for fire intruder and the CCTV.
We've got a Twinflex going into the cottage + annexe, but then again I'm a bit mental...
Edited by datadiffusion
When we used to fit 12V smokes & heats on Gardtec 816s and the like, we used these resistor packs from Elmdene I think (or was it Dantech?) which avoided
messing about, they worked out about 20p in bulk IIRC. We used to fit quite a lot though.
