sixwheeledbeast Posted November 27, 2016 Share Posted November 27, 2016 So your not using something like a JAC-0001 onto the CDH-0001? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40567-pyronix-homecontrol-vs-visonic-powermax-vs-texecom/page/31/#findComment-453999 Share on other sites More sharing options...
1animal1 Posted November 27, 2016 Author Share Posted November 27, 2016 Nope - I've read several forum posts that suggest third party leads do work if using FTDI chips. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40567-pyronix-homecontrol-vs-visonic-powermax-vs-texecom/page/31/#findComment-454000 Share on other sites More sharing options...
sixwheeledbeast Posted November 27, 2016 Share Posted November 27, 2016 Never tried. I have seen websites with posts about DIY leads but I don't recall anyone flashing with them. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40567-pyronix-homecontrol-vs-visonic-powermax-vs-texecom/page/31/#findComment-454003 Share on other sites More sharing options...
datadiffusion Posted November 27, 2016 Share Posted November 27, 2016 (edited) If you bought your lead from ebay there is a very high chance it isn't really FTDI even if it says it is - or even if your computer says it is! CPC sell genuine FTDI modules (basically a USB plug on a tiny PCB with 3 solder terminals) for TTL type use, or of course there is the genuine texe item as above. Edited November 27, 2016 by datadiffusion So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40567-pyronix-homecontrol-vs-visonic-powermax-vs-texecom/page/31/#findComment-454010 Share on other sites More sharing options...
james.wilson Posted November 27, 2016 Share Posted November 27, 2016 just a little question. You bought an unsupported adapter? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40567-pyronix-homecontrol-vs-visonic-powermax-vs-texecom/page/31/#findComment-454014 Share on other sites More sharing options...
1animal1 Posted November 27, 2016 Author Share Posted November 27, 2016 Thanks Data - The FTDI adaptor will probably be the way to go cost wise - thanks for that James - yep, bought an ebay cable which has done the trick so far Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40567-pyronix-homecontrol-vs-visonic-powermax-vs-texecom/page/31/#findComment-454034 Share on other sites More sharing options...
1animal1 Posted November 28, 2016 Author Share Posted November 28, 2016 Looking into this further via several really interesting blogs https://gw0udm.wordpress.com/category/texecom/page/2/ - it appears that my lead may well be 100% compatible - before i try to knock up a similar TTL-FTDI module-cable - I am going to try again on a different laptop. Do the easiest things first.... Fingers crossed..... I've also had a tiny bit of success with the remote access. Using the NoIP port checker i discovered my port was open from the outside and that upon using their configurator, I managed to get remote access! however only once....i then tried again several times and it wouln't connect again. Ran config on NoIP again and again i got it working once. I've since tried a different port to no great effect... stumped! Tried resetting the SKY router to factory settings then reloading the backup file - nothing....It works as I've connected my DVR via Ethernet this weekend and port forward that, with success. So next will be to take a couple of hours off from the day job and call Texecom to hopefully go through it with a fine tooth comb. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40567-pyronix-homecontrol-vs-visonic-powermax-vs-texecom/page/31/#findComment-454046 Share on other sites More sharing options...
1animal1 Posted November 28, 2016 Author Share Posted November 28, 2016 ....and we have a third update, I'm sure your all sat on the edge of your seats waiting for this - after going through the panel with Texecom, and reverting back to the standard port and adjusting the gateway to end 000, instead of .255. All is working on the app remotely. Relieved is an understatement as well as being slightly annoyed with myself that something so simple could remedy. Whilst on the call i asked about the firmware issue and got a small tip about the heartbeat light going out once the board has been reset properly - indicating it was ready to receive the update, and also about making sure the plug is inserted the correct way around on the panel! The panel plug doesn't have anything to ensure it cannot be inserted upside down - what felt like the natural position was infact wrong. I now have V3 on the panel Now I hope this V4 and new app isn't too far behind Massive thanks to Rob at Texecom tech support for all his and his colleagues help. I would also like to say a huge thank you to everyone that has helped me out on here - I have a feeling you know this already, but i really could not have got this far without you all - special thanks to SWB, James, Al and Data (sorry if I've missed anyone). I don't want this to sound condescending, but i really have a new found respect for alarm engineers - i started out this job thinking how hard can it be having fitted what i now know, basic alarms previously! I am fully aware that i have only touched the surface of what you guys do but seriously - HUGE respect is due - especially given the additional complexities that are being added all the time, it must be extremely difficult staying on top of it all then rocking up at someones house knowing exactly what you are doing. I hope this thread goes some way to helping others on future installations - at the very least it may stop someone asking a silly question Tim Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40567-pyronix-homecontrol-vs-visonic-powermax-vs-texecom/page/31/#findComment-454050 Share on other sites More sharing options...
norman Posted November 28, 2016 Share Posted November 28, 2016 Nice to hear Texecom are continuing their first class non trade support. Pleased you have it sorted... 1 Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40567-pyronix-homecontrol-vs-visonic-powermax-vs-texecom/page/31/#findComment-454051 Share on other sites More sharing options...
al-yeti Posted November 28, 2016 Share Posted November 28, 2016 I like the plug reversal thing haha And of course a big thankyou for another firmware update 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40567-pyronix-homecontrol-vs-visonic-powermax-vs-texecom/page/31/#findComment-454052 Share on other sites More sharing options...
