lymebayalarms Posted October 23, 2016 Share Posted October 23, 2016 34 minutes ago, Amps said: My first choice would be this quad detector: https://www.pyronix.co.uk/products-and-solutions/kx15dq Easily available online for around a tenner each. Great value imo. If you are thinking about updating the panel it depends on what options you require. If like most you would like to control your intruder system by using an App then the Pyronix Enforcer HomeControl+ would be ideal. This may be a little expensive though and you would also need a expander for your detectors. Certainly worth considering though imo. https://www.pyronix.co.uk/products-and-solutions/enforcer-homecontrol-panel As for a straight swap for you Abacus the the Pyronix Euro Mini would take some beating. Again easily available online for approx £65 which is outstanding value. Btw i am not a Pyronix Rep but have been installing their equipment for 15 years and highly recommend it. Second the Pyronix Quad. Pryronix Euro 46 is now APP compatible. Quote Link to comment Share on other sites More sharing options...
Amps Posted October 23, 2016 Share Posted October 23, 2016 5 minutes ago, lymebayalarms said: Pryronix Euro 46 is now APP compatible. I've been waiting for this m8. Will a v9.1 Euro 46 work with the APP? Excuse my ignorance but is the Lan Module all that is required? http://www.ebay.co.uk/itm/Pyronix-Enforcer-Wireless-HOME-CONTROL-DIGI-LAN-MODULE-UK-Stock-DAILY-SHIPPING/361487484666?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3D1298df279f084449afa9f8e8c3727303%26pid%3D100338%26rk%3D1%26rkt%3D15%26sd%3D272129804885 Quote Link to comment Share on other sites More sharing options...
petrolhead Posted October 23, 2016 Share Posted October 23, 2016 Nope needs to be euro46 app version. You lose intelligent set too. Quote Link to comment Share on other sites More sharing options...
Amps Posted October 23, 2016 Share Posted October 23, 2016 3 minutes ago, petrolhead said: Nope needs to be euro46 app version. You lose intelligent set too. Ok cheers. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted October 23, 2016 Share Posted October 23, 2016 5 hours ago, PeterJames said: Why dueltec Imran?? Why not? Quads then lol Quote Link to comment Share on other sites More sharing options...
PeterJames Posted October 23, 2016 Share Posted October 23, 2016 Everyone thinks that DT's are better and they are in the right environment, which is usually a more hostile environment than a house. I would use quads every-time over DT's in a domestic environment. Apart from in the garage, even then depending on the environment of the garage, you could sleep in mine on a cold winters day no problem so a quad is fine. 1 Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted October 23, 2016 Share Posted October 23, 2016 (edited) Yup had a Siemens IR240 in a garage (one uninsulated wall and the door, rest part of house) on one job against my feelings at the time, been fine for ten years, panel set daily. Of course, it's been dissed for 9 of those years (joke) Edited October 23, 2016 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
al-yeti Posted October 23, 2016 Share Posted October 23, 2016 But dt will still do the job nicely Quote Link to comment Share on other sites More sharing options...
PeterJames Posted October 23, 2016 Share Posted October 23, 2016 Well....you say that but I would beg to differ Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted October 23, 2016 Share Posted October 23, 2016 Bosch BluLine or Optex, would be my brands of choice. Wouldn't fit a sensor without sealed optics. Quote Link to comment Share on other sites More sharing options...
