Setting up a Twin Piezo Sound Bomb
its not a speaker. If you want spk tones then get a speaker
  • Replies 36
  • Views 14.7k
  • james.wilson
    james.wilson
    I must say you have got half pro gear and have no idea how to use it. time to get someone in that does?
  • I'd normally just use separate OP's
  • I'd put the red on + & use op1 on black programmed as something suitable?   But then again it's late & I've been drinking....
@al-yeti - not sure mate.  How can I check?
@james.wilson - Your right, but because the alarm panel is wired in the basement, we don't have loud enough sound from keypad to alert us if an intruder managed to break-in.
@sixwheeledbeast - The original speaker is still on there too.  Can't I keep both?  They seem to be working fine and the sound-bomb is more than loud enough to wake the whole house up.
the keypad is just that low volume feedback etc
1 hour ago, Newbietexecom24 said:
Whenever I connected the black wire to the bell, it continued to beep.
texecom bells have leaky triggers....
1 minute ago, Newbietexecom24 said:
@MrHappy Leaky triggers?  What's that and how do I resolve it?
Diode or bleed resistor?
I've got to agree with you and hold my hands up.  Before I bought this alarm system, I thought I'd figure it out pretty quickly, but now I realise that I have bitten off more than I can chew.  I am almost there and majority of alarm system seems to be working fine, but some of the technical stuff I certainly do struggle with.
