Hikvision Hdtvi Any Good?
  • Replies 37
  • Views 11.9k
  • Is it me or is HIK vision way overhyped? I've never used it before until yesterday & I'd say it looks cheap & nasty which runs in like with what they paid for it so no arguments on that point
  • james.wilson
    james.wilson
    After importing and supporting gear I think your wrong
I had exactly the same issue, wish they would have HDMI, BNC & VGA outputs so you would have plenty of options
7300 series has all these.
  • 3 weeks later...
You can have alarm monitoring via IVMS 4200 Software just needs setting up. It will also work with IVMS7000 from LTS Security Inc., I assume they rebrand Hikvision Stuff for the USA Market. Only downside I have noticed on the 16ch model (Without Alarm Inputs) is that if you did want to use some kind of monitoring ie through the Line Cross Detection feature only works with one Channel.
However IP Cameras on the same DVR can have line cross detection as its direct in the camera software, On the IVMS you add them as new devices but add them to the same group (Site).
Other than that it looks good kit just a shame you cant have Line Cross detection on more than one camera
Also Alien DVRs will work through both the IVMS software's.
ip cameras have the feature so it can be used.
the turbo or anl;ougue cameras dont have the function built so  depending on the DVR, you can have 1 or two anlogue/turbo devices with the VCA. The HQ series allows two the cheaper DVR model allows 1.
  • 10 months later...
Hikvision seems to be all over the internet now I have not heard any bad press on the kits, who are the main distributors of Hikvision in the UK..?
21 minutes ago, sixwheeledbeast said:
No bad press?
https://ipvm.com/reports/the-hikvision-hacking-scandal
Available everywhere, ADI, DVS, Norbain, Maplin...
eBay sell lots to
On 18/01/2016 at 3:31 PM, secureiam said:
i ams sure i have mentioned them on here and waiting for answers  from supplier/ HIK.
Hi, we could supply Hik products.
Edited by norman
Contact details removed, please read the rules.
Hi Wang,
Where are you based? Do you do all the Hikvision range?
China hik, you looking to buy direct from them?
