Eurosec Cp8L Lcd Battery Replacement
chrisb70
Hi everyone, hope all's good with you!
I wonder if anybody would be able to shed some light here.
I've got a Eurosec CP8L LCD house alarm, pre-installed (presumably by the builders) in the house I bought from somebody else 2 years ago.   I do know the Engineer code and the User code.
when we moved in, there was a "!!!! CHECK !!!! Low Batt." reading on the alarm, so fair enough, I bought a new battery, unscrewed the box in the garage, got the tamper alert, replaced the battery and all was well.
Fast forward to now, and there is another "!!! CHECK !!! Low Batt." reading.
Firstly, is that expected?   It's only been 2 years since I replaced it.
Secondly, I did the exact same procedure as above (well, so far as I remember) and the system still says "!!! CHECK !!! Low Batt." even though it has a new battery.   What did I do wrong?   Is it the Fuse?  Or do I need to do a reset/power off?
Thank you for any and all help :)
cheers, Chris
Link to comment
Share on other sites
Depends - if you've had a few power cuts (or more likely, power turned off all day for building work etc...) then the battery will last nowhere near as long if completely discharged.
Link to comment
The battery (both the ones I've bought) are Yuasa.  Er, are they any good?
Yes.
Originally said by Charles Babbage
On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
Link to comment
