Texecom Premier Elite 24 Guard Access
Hi, can you help me with an  Arming programming question please.
Texecom Premier Elite 24.  Wintex software. 2 keyboards.
One area only Area A.
No Area Suites set up.
KB1 in  final exit /entry zone.
Door contact final exit /entry programmed  as entry/exit 1, ommitable, Auto rearm.
Two PIRs in entry exit zone both programmed as Guard Access. Ommittable. Access. Auto Rearm.
Question:
When Arming at the keyboard near the final exit door I am in the sight of the two PIRs which  at the moment of arming are active of course. This causes an arming fault and indication shows the PIRs are preventing Arming. if these PIRs are set to NOT USED then arming is OK.
Is this normal or not as I believed that the Guard Access plus Access attributes prevented this. Or do these attributes only supress activity at exit after the alarm has been armed or reached  exit mode.
More simply put how can I arm with the PIRs active.
  • Replies 46
  • Views 22k
  • Over and above the call of duty possibly for a forum, phone calls etc, just saying-my take only, any views anyone?.
You can't that would defeat the object of the alarm.
Pirs on exit route should be exit zones not sure what Texe label that type of zone as though , then they should ignore you on arming until set , or something like that
They should never ignore you unless isolated.
the final door is entry exit, pir's on the entry/exit route should be guard access.
reset the zone program to not used then back to guard access.
That should allow you to set the alarm walk past the pir and out of the door, if that's still not helping then need to look at the arming method in more detail.
The keypad will display active zones and if it's just picked you up does tell you that zone is preventing arming to make you check you have not missed something
what happens if with the zones for the pirs set to guard access
Enter you code, do you want to arm ( Yes )
Display showing Zone preventing arming Pir?
Then press yes again and leave.
Does it set or not and what happens when you come back in does it (entry) and disarm and show no faults ?
....what happens if with the zones for the pirs set to guard access
Then press yes again and leave......
The pirs are set guard access and attribute Access as noted in my question
do you want to arm -yes
area in exit
area arm fail
pir 1
pir 2
 if I press yes again area arm fail persists.
The above happens when i remain by the KB through the area in exit period,
if I leave by exit door when area in exit, arming fails also.When entering it shows area arm failed.PIR 1 PIR 2
are these pirs in alarm all the time
what did diy tech support say?
area in exit
area arm fail
pir 1
pir 2
Something is programmed incorrectly. This shouldn't happen.
Call a local installer?
