magpye Posted August 24, 2007 Share Posted August 24, 2007 half and half - it was a flyer from yuasa iirc claimed that marker pen or even the sticky from using insulating tape would degrade the plastic and lead to gas escaping though obviously if you bought there special " battery marking kit " there wouldnt be an issue didnt they once publish a chart with the degree`s over optimum to hours off expected life formula plotted out ( every 5 degrees looses an hour ish ) CONFORMATION Received today, 24-08-07 From - Technical Services Manager (Yuasa Battery Sales UK) ......... our install guide mentions not to use organic solvents or adhesive on or near the batteries. We have found that most insulation tapes and paper stickers are okay and do not cause damage. Generally if a substance smells like a solvent or is oil or grease based, then do not use it on or near the batteries. So, no permanent marker pens then!! Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment Share on other sites More sharing options...
arfur mo Posted August 24, 2007 Share Posted August 24, 2007 CONFORMATIONReceived today, 24-08-07 From - Technical Services Manager (Yuasa Battery Sales UK) ......... our install guide mentions not to use organic solvents or adhesive on or near the batteries. We have found that most insulation tapes and paper stickers are okay and do not cause damage. Generally if a substance smells like a solvent or is oil or grease based, then do not use it on or near the batteries. So, no permanent marker pens then!! and no terminal anti-corrosion grease either then regs alan If you think education is difficult, try being stupid!!!! Link to comment Share on other sites More sharing options...
alterEGO Posted August 24, 2007 Share Posted August 24, 2007 CONFORMATIONReceived today, 24-08-07 From - Technical Services Manager (Yuasa Battery Sales UK) ......... our install guide mentions not to use organic solvents or adhesive on or near the batteries. We have found that most insulation tapes and paper stickers are okay and do not cause damage. Generally if a substance smells like a solvent or is oil or grease based, then do not use it on or near the batteries. So, no permanent marker pens then!! MINE DOSN'T SMELL and there ain't a chance in the world i will change my method of marking a battery. sometimes it has to be said 'GET A LIFE' Link to comment Share on other sites More sharing options...
antinode Posted August 24, 2007 Share Posted August 24, 2007 I'm not having that. I've seen batts over 10 years old dated with a marker with no obvious ill effects. Trade Member Link to comment Share on other sites More sharing options...
Guest anguscanplay Posted August 24, 2007 Share Posted August 24, 2007 some one ought to close this before me and magpye get to be friends grr lol Link to comment Share on other sites More sharing options...
amateurandy Posted August 24, 2007 Share Posted August 24, 2007 I'm not having that. I've seen batts over 10 years old dated with a marker with no obvious ill effects. I hope you took them out of service immediately! Link to comment Share on other sites More sharing options...
magpye Posted August 24, 2007 Share Posted August 24, 2007 some one ought to close this before me and magpye get to be friends grr lol Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment Share on other sites More sharing options...
whistle Posted August 24, 2007 Share Posted August 24, 2007 You Sad ********** Use a marker pen like 99.9% of companys, if you put as much effort into working and macking a proffit as you do about moaning on about dating batts with marker pens causing problems you might start to get a life. Please refrain from trying to bypass the bad word filter. Link to comment Share on other sites More sharing options...
C.S TEK. Posted August 24, 2007 Share Posted August 24, 2007 You Sad ************Use a marker pen like 99.9% of companys, if you put as much effort into working and macking a proffit as you do about moaning on about dating batts with marker pens causing problems you might start to get a life. lol they got to much time on there hands! Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006 Link to comment Share on other sites More sharing options...
alterEGO Posted August 24, 2007 Share Posted August 24, 2007 You Sad *************Use a marker pen like 99.9% of companys, if you put as much effort into working and macking a proffit as you do about moaning on about dating batts with marker pens causing problems you might start to get a life. lol QFA Unreal, i cannot belive someone would contact yuasa to ask such a thing WTF! Link to comment Share on other sites More sharing options...
