David R joined the community
Mitchee joined the community
Still seems the same to me -
al-yeti started following Anyone seeing this yet and Nexus 8 Wired Alarm
- 22 replies
- 22 replies
Kyle92 joined the community
- 22 replies
I don't know of any panel that would chime on close. Yep, as above using a Mimic output and some other logic like a toggle relay or custom outputs would be the way to go.
Who's Online 1 Member, 0 Anonymous, 55 Guests (See full list)
Total Topics446.5k
