- Past hour
al-yeti started following Anyone seeing this yet and Nexus 8 Wired Alarm
- 22 replies
- 22 replies
Kyle92 joined the community
- 22 replies
- 22 replies
- 22 replies
- 22 replies
- 22 replies
DeedPopo joined the community
- 22 replies
Like most sounders the Twin alert manual has the wiring instructions for different manufacturers. Aux Tamp / Aux Tamp / Bell / Spk- / 0V / +12V
Who's Online 1 Member, 0 Anonymous, 67 Guests (See full list)
Total Topics446.5k
