Mitchee joined the community
Still seems the same to me - Last week
al-yeti started following Anyone seeing this yet and Nexus 8 Wired Alarm
- 22 replies
- 22 replies
Kyle92 joined the community
- 22 replies
- 22 replies
Indeed, personally I can't get my head around people not using part set, why wouldn't you, once set up right it's great, press 2 keys, and go to bed........ In part set I have the whole of the downstairs and the two upstairs rear bedroom windows armed, (Single storey flat roof at rear so those windows are vulnerable) the landing off and the stairs timed, allows everybody to go to the loo during the night........
Who's Online 0 Members, 0 Anonymous, 14 Guests (See full list)
Total Topics446.5k
