To put that in english: Type the user code that works, press no till you get to CD press Yes then enter the four digits you want to use, and a gain a second time to confirm
Allot has changed since your release.... Eagle is same tho, I think...- 1 reply
- 1
al-yeti started following Anyone seeing this yet and Nexus 8 Wired Alarm
- 22 replies
- 22 replies
Kyle92 joined the community
- 22 replies
- 22 replies
- 22 replies
Who's Online 0 Members, 0 Anonymous, 96 Guests (See full list)
Total Topics446.5k
