Still seems the same to me -
- 22 replies
- 22 replies
- 22 replies
I don't know of any panel that would chime on close. Yep, as above using a Mimic output and some other logic like a toggle relay or custom outputs would be the way to go.
Who's Online 0 Members, 0 Anonymous, 50 Guests (See full list)
Total Topics446.5k
