security master tp-800 pre wired alarm problems!
if you are a newbie member (<15 posts) then you cant use profiles or pm's
I am a new member and cannot view profiles as yet.
  • Replies 77
  • Views 33.6k
  • tbf fair for 3 squid you could bang it on fleabay and get 20-30 I reckon.
  • datadiffusion
    datadiffusion
    Those instructions in full;   Turn off mains Remove battery Remove all traces of TP800 equipment Place into bin Contact a local installer, or, fit a DIY Scantron
  • datadiffusion
    datadiffusion
    Good luck with that, since you have to go back 12 years just to get a sniff of the original website...   OP, it's tat, I'd bin it. I've unwittingly taken about 5 of these out over the years,
<15 means less than fifteen posts.
In otherwords you need to make 15 posts before the system allows you to view profiles etc.
  • 7 years later...
Hello and help,
please please can somebody help me with a Manual for an old pre-wired alarm, it's the TP-800 by security master is this thread.
please.
id be so gratfeul
Edited by sixwheeledbeast
no contact details in posts, please
make the pic big & there's a telephone no. & email address...
personally I rip it off the wall & buy a proper one...
Looks like you even get a screwdriver.... None of this buy your own here!
OP, it's tat, I'd bin it. I've unwittingly taken about 5 of these out over the years, tellingly only the 2-wire sirens were ever left,
I never knew the make since, for some strange reason, the control panel bits were long gone... :hmm:
https://web.archive.org/web/20040401064807/http://www.tdbm.com/
Dear dufjax and data diffusion.
thanks for both your posts. I agree the device is poor quality. But I'm only use interface it to protect 3 outbuildings on my farm. I found it in a charity shop for 3 quid. Brand new,,just no distractions!!!!
so thought worth a shot. I've tried the phone number and website l, both are a no go.
datadiffusion - is the link to the instructions ? Sorry mate, but if it is it does not work!
thanks
They robbed you...
thanks
Does it work have you tried powering it up?
It does says it's pre wired on I assume you just plug the PIR's, Door Contact and Siren in?
You could try some standard PINs, (which I won't state here because it's against the rules) you know the sort of thing you would NEVER use for a card pin number.
Apart from that the only reference to it seems to be this thread.
1 hour ago, MrHappy said:
They robbed you...
For £3 it was probably worth the punt.
