Break glass keeps going off
Hpatz1
It’s a high value shop. We have done the install and now are getting Chubb to take over and do monitoring and maintaince. Should be a grade 4 once finished with signalling ect
we want to know that the glass is broken before then enter as it’s bullet proof glass
Link to comment
Share on other sites
The comment regarding Grade 4 shows complete misunderstanding...
Curtain PIR, Beams, Foil, all probably much better options.
Make sure your glassbreak supports bulletproof/laminated glass consider how the shutter will affect detection, if you ignore us.
Chubb may want to rip half of it out if it's not to spec anyway.
  • Upvote 1
Link to comment
Glass break detectors don't usually work on bulletproof glass is it actually bulletproof?
Grade 4 signalling is available but grade 4 detection isn't.
What are the insurance requirements?
I'd suggest shock detectors would be better and quicker than glass break assuming suitable ie not a main road.
Also if you have installed it check chubb will do the failure to perform cover.
Link to comment
LOL!
Link to comment
It’s a high value shop. So you decided that you needed to skimp on the security and fit it yourself We have done the install and now are getting Chubb to take over and do monitoring and maintaince. If you havent done it properly they will want to rip it out and start again, not only that all of the detection and panel is not going to be covered by their warranty and they wont let you touch it if they do take it over. Not sure that they would want a premier anyway. Should be a grade 4 once finished with signalling ect This tells me you know very little about security systems and you think the higher the number the better the security. My dad is bigger than your dad.
we want to know that the glass is broken before then enter as it’s bullet proof glass  If someones broken the glass there already in
What are you selling?
Link to comment
