Break glass keeps going off
22ct gold jewellery would be my guess...
  • Replies 39
  • Views 4.8k
  • sixwheeledbeast
    sixwheeledbeast
    The comment regarding Grade 4 shows complete misunderstanding... Curtain PIR, Beams, Foil, all probably much better options. Make sure your glassbreak supports bulletproof/laminated glass co
  • I eat cannibal,It's incredible...
But not behind a 'bulletproof" window with risco detectors done as a diy job Sounds like a setup for a film. No one tries diy on high value goods surely?
Remind me risco do the cheapest stuff or the best stuff?
46 minutes ago, norman said:
Shall we have a wager?
On the takeover, or bacon sw on the first day
44 minutes ago, al-yeti said:
I need to do bullet proof glass on my installs.....
It's proper rare, some sell laminated as it but real bullet proof is huge. I did a gkn contract where they made it for hummer windows must of been 75mm thick a weight was as expected. In a shop window I'd say unlikely.
But I was wrong once etc
That the high value goods are mainly 22ct.
Costly mistake spending a load of money on DIYing G3 stuff only to be told by the installer that they wont take it on.
On 20/10/2023 at 22:09, Hpatz1 said:
 as it’s bullet proof glass
I guess you either in the Bronx or Tooting ?
I'd go with brum due to the 'bulletproof' glass. Either needed or hoped for. I still say it isn't bulletproof
Don't need glass break detectors for that
I do hope the op and chubb sort it out though hopefully without double knock on any circuit
