Rebecca 7 Posted April 12 Share Posted April 12 (edited) Hi All Around 2010 I had a Risco Agility (version 2 I think) alarm installed and it has worked swimmingly ever since. At the end of last year I popped some new batteries in the external sounder but couldn't clear the 'low battery sounder' warning on the display, (changing the batteries were the limits of my skills!) so I called in an alarm company to save the day. The alarm company (well, a lone guy working for himself) changed my new batteries in the sounder (advising that it's better to use well known branded batteries) and cleared the low battery code on the system. All worked well for the last few months but the 'low battery sounder' has reappeared and the alarm guy is coming up with all kinds of excuses not to come clear the code, to the point where he is now ignoring my calls. As I say, my skills are very limited but I have downloaded the Agility installer manual in the hope I can follow steps to clear the low battery warning. I can see the instruction to press the * button, followed by ##REMOVED## (the default installer code), but I'm lost after that. Any suggestions would be HUGELY appreciated . Thank you, Rebecca Edited April 12 by sixwheeledbeast no codes in posts please Quote Link to comment Share on other sites More sharing options...
james.wilson Posted April 12 Share Posted April 12 If its burning through batteries id suggest the sounder has an issue Quote securitywarehouse https://store.securitywarehouse.co.uk Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
MrHappy Posted April 12 Share Posted April 12 59 minutes ago, Rebecca 7 said: Any suggestions would be HUGELY appreciated . remove & replace the full system. The batteries in the sounder will require replacing again as the device has gone gaga & now eats the batteries. I programmed a sounder off over the weekend & 20 hours latter it decided to flag up line fault despite ever been connected to telephone line You can default & reprogram them but they will keep doing weird & wonderful faults Quote Mr Veritas God Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted April 12 Share Posted April 12 I don't like working on these things, as above they do daft things. You end up power cycling them or reprogramming them to clear weird faults. From a DIY POV you are already at the limit of your ability as you say, so your left with finding another installer. You could put another set of batteries in and hope. You will likely be able to clear most faults with your user code, arming then disarming. I would want to replace the system for something else if it wasn't as simple as batteries. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted April 12 Share Posted April 12 1 hour ago, sixwheeledbeast said: I don't like working on these things, I'd rather be stabbed... 1 hour ago, sixwheeledbeast said: I would want to replace the system for something else if it wasn't as simple as batteries. I'd look to replace the EWD, however the £ would be better put towards something different Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Amps Posted April 16 Share Posted April 16 (edited) Make sure the strobe option is set as Follow Bell. I had a customer who had intermittent tamper faults sometimes taking days to restore. If the strobe was programmed as Follow Alarm it would activate on any alarm including tamper. Batteries lasted a matter of weeks. I'd seriously consider replacing the Risco Agility kit with a Pyronix Enforcer. Risco is good but only to engineers who use it day in day out. Edited April 16 by Amps Quote Link to comment Share on other sites More sharing options...
PeterJames Posted April 16 Share Posted April 16 Risco does seem to have form for this sort of thing, replace batteries and stuff stops working smokes where always doing that on gardtec stuff as well Quote Link to comment Share on other sites More sharing options...
james.wilson Posted April 16 Share Posted April 16 1 hour ago, Amps said: Id seriously consider replacing the Risco Agility kit with a Pyronix Enforcer. Risco is good but only to engineers who use it day in day out. I wouldnt go pyronix anything my 2p Quote securitywarehouse https://store.securitywarehouse.co.uk Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
PeterJames Posted April 17 Share Posted April 17 20 hours ago, james.wilson said: I wouldnt go pyronix anything my 2p tbf she has a Risco panel Quote Link to comment Share on other sites More sharing options...
Amps Posted April 18 Share Posted April 18 On 16/04/2022 at 23:18, james.wilson said: I wouldnt go pyronix anything my 2p Why not? Quote Link to comment Share on other sites More sharing options...
PeterJames Posted April 18 Share Posted April 18 15 minutes ago, Amps said: Why not? Each to their own I suppose but it would not be my weapon of choice. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted April 19 Share Posted April 19 (edited) On 18/04/2022 at 19:28, Amps said: Why not? As a standalone panel with no remote keypad , none of them are very good, although the quantam 70 looks better , easier to maintain with hinged lid , whereas the enforcer has to hang off it's cables , or have they fixed that issue? Is it still difficult to fit extra coms device in in side it ? I think it would do better if they changed the menu style and it's casing Apart from that you know it's just a panel that sells on bulk and it's more about money not about the product The texecom all in one panel works well , lots of room but looks like a brick Quantam comes out in top imo Edited April 19 by al-yeti Quote Link to comment Share on other sites More sharing options...
MrHappy Posted April 19 Share Posted April 19 1 hour ago, al-yeti said: The texecom all in one panel works well , lots of room but looks like a brick More like a breeze block you could butcher a webway nano into it or have dopey connect nailed onto the wall next to it... only does 4 wired zones Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Amps Posted April 24 Share Posted April 24 On 19/04/2022 at 21:26, al-yeti said: whereas the enforcer has to hang off it's cables The lid hooks onto the the two fastening screws. Quote Link to comment Share on other sites More sharing options...
