SW1070 Panel: Tamper or Sensor Triggered Alarm?
1 hour ago, Eugene's DIY Den said:
Can I use a double knock option on the same zone to only trigger an alarm after several operations of the PIR?
HKC have a wireless Dualtech now its much better for hostile environments like sheds and garages
  • Replies 22
  • Views 4.4k
  • PeterJames
    PeterJames
  • as I said to the postman today, 20 is plenty...
  • james.wilson
    james.wilson
    If its a pir in a shed that isn't a great idea
3 hours ago, sixwheeledbeast said:
You can, but you shouldn't.
agreed its an awful option and should never be used
If its wired use a dt, if rf use the hkc dt or better still dont use space protection in a shed
Doesn't work well for fa
Hkc pir won't trigger as fast as normal standard pirs might be better option or the wireless as said above
as in more stable or slow?
Hkc pirs are stable plus they don't trigger on just a slight movement , not sure how to describe it lol
  • 2 weeks later...
What's the approximate line-of-sight range (for the radio signal) of those?
Its the same as the rest of the wireless kit
"Developed by our in-house R&D team, the detector has exceptional RF range allowing it to be positioned in the trickiest of locations"
https://www.hkcsecurity.com/Other/hkcsecurityCOM/Public Downloads/Ireland/Intrusion - Wireless/RF-PIR-DT.pdf
I have tested extreme range of this, on a farm environment it was about 1km. At the time wish I had the powered mesh unit in theory I could of got 8, I will at some point do range testing on the leading manufacturers, but that needs a beach to be fair
2 hours ago, sixwheeledbeast said:
Trip to the Nederlands...
Lol
Odd place that , it's built in some kind of sand right? Or parts of it
