SW1070 Panel: Tamper or Sensor Triggered Alarm?
Something in the shed triggered my alarm last night. I'm thinking warm air currents in front of sensors or tamper contacts stick/slipping in this heat because of expansion/contraction or maybe bats. Does this panel differentiate between an alarm triggered by a sensor in a loop on a zone or the alarm triggered by a tamper going o/c on that zone? The panel just says a"Alarm" with the zone name. These false triggers  are infrequent, maybe one or two a year, but always seem to happen in really hot weather.
Edited by Eugene's DIY Den
  • Replies 22
  • Views 4.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • PeterJames
    PeterJames
    HKC have a wireless Dualtech now its much better for hostile environments like sheds and garages
  • as I said to the postman today, 20 is plenty...
  • james.wilson
    james.wilson
    If its a pir in a shed that isn't a great idea
All systems should show alarm, tamper and (if radio) battery faults separately, it's an important part of diagnosing a false alarm event.
Unless you wire something up wrong, an alarm is the sensor triggering be that a fault or the environment.
So should it specify zone number, name, followed by type of alarm triggering event? I'll check if this actually does happen and report back. If it doesn't, does it mean I have detailed alarm event reporting turned off in the menu somewhere?
Tamper means exactly that the lid has come off something, or if hwired the cable may be damaged
hkc  will normally verbally tell you the  fault "tamper zone 3"
My alarm normally faults on the day everyone goes out (as we get to door) or heat is a problem , original wiring was loft and PSU can't take intense heat lol failed yesterday
Galaxy dimension was bullet proof PSU transformer
Yes, I just confirmed that.
Can I use a double knock option on the same zone to only trigger an alarm after several operations of the PIR?
You can, but you shouldn't.
