How do I get this to work?
2 hours ago, al-yeti said:
Leave coms til last , mount your panel and keypad , c078 , and the coms boards should already be mounted hopefully
Switch on and see what faults you get, work through one by one
You see that’s the problem, what should go through the C078 and what goes straight to the box? Should I have the keypad go in on 12V 0V A B on the right hand side? And what should I have going to OP2? I’ll post some pictures on how it look after I cut the cables. Maybe someone would be able to say what equipment been connected to what port.
  • Replies 63
  • Views 14.7k
  • Put your hand in your pocket and purchase a Pyronix Enforcer wireless  kit. Save you lots of hassle and well worth the ££.
  • Not sure id agree on the enforcer bit but its the right idea if you have no clues on what to do, wireless is ideal for DIY
  • sounds very unlikely ?
14 minutes ago, Henrik said:
No, apparently not!
Bizarre
2 hours ago, Henrik said:
Unfortunately I’m not aloud to have a wireless alarm system due to having a goldsmith studio in the basement. My insurance company demand a wired alarm system.
I would be double checking what your policy says if I were you, I think it highly unlikely that an insurance company would accept anything less than a system installed by an accredited company with at least dual-path grade 3 monitoring. I would expect that a goldsmith studio will hold theft attractive stock and property, and I would expect the value of the contents to be in the thousands not the hundreds. Does your policy mention Police response?  Just trying to save you a whole lot of heartache
1 hour ago, Hillbilly said:
Oh it’s going to be a long install!
 not necessary.
I have checked with the insurance company and as long as I can prove the system works and with video recording in the event of an break in it ok. I do not have to have police or security company response for the insurance. Absolutely true about the money, it’s well over 10s of thousand in storage.
But enough about my insurance.
is there anyone that could help me a bit with the wiring of this system?
if this was your system how would you hook it up (with all the marks on the equipment mentioned).
Wouldn't happen in the UK, insurers like to cover their bets here
But we already told you where to start?
Are you basically saying you don't have a clue how to find the manual to atleast wire the keypad to the control panel
If you can't get that bit done , I would forget Bout this .....
