How do I get this to work?
it should be changed for security reasons
  • Replies 63
  • Views 15.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Put your hand in your pocket and purchase a Pyronix Enforcer wireless  kit. Save you lots of hassle and well worth the ££.
  • Not sure id agree on the enforcer bit but its the right idea if you have no clues on what to do, wireless is ideal for DIY
  • sounds very unlikely ?
Posted Images
55 minutes ago, Henrik said:
Ok guys, got everything up and running just fine.
i do however have an slight issue.
when I took the alarm down I most have missed one PIR hanging on the wall (address 1002).
how do I go about entering the engineer code to be able to delete the address 1002?
And is the engineering code always the same or is it changeable by the company who first installed the system in my old shop?
thanks in advance,
Henrik.
You need to mark zone 1002 as spare which i believe is option 52 on galaxy
On 24/10/2020 at 21:16, PeterJames said:
okay a higher chance then
Still doubt it  the monkeys still haven't had thier bananas
Edited by Imnotshankled
Am I doing this in the right order when trying to access the eng mode?
48 ent, 1 ent, 1 ent, 1 ent (eng code) ent?
When I do this nothing happens.
does it tell me I have entered the wrong eng code or not?
No you just enter the engineer code from day
Thought it has to be enabled ?
thanks in advance,
Henrik.
While your stuck get a resistor and put it across 1k and it should stop it from throwing the error until you work something out
good point it does, for some reason i thought it was a classic
Classis is me lol
So enable in menu 48 , and then enter engineer code
 But OP more than likely you don't have it so try the resistor and then you might be lucky if it's all user reset
3 hours ago, al-yeti said:
Classis is me lol
Did put a 1K between 1002 and 0V but still getting the +SAB fault code on 1002 and did nothing, also got the same code on 1003 but I got all the cables in the right places gonna try a Wago clip just to see if its the cables that's not connected properly.
No one out there that could help me via PM on how to reset this system of mine?
You got a picture of where you put resister?
Must mean zone 2 was being used as a sab tamper maybe?
But earlier you said it was a PIR
So when you say you get +sab and 1002 are you sure these are not separate faults and your not confusing matters
